Wishing you and yours a happy, safe and RV-filled weekend!
v/r,dr
SmoothAirCruiser
kens_cockpit
Ironflight
DonMcKee -014
TheBoatLife
Ironflight
Mothership
www.vansaircraft.com
OFF TOPIC:
v/r,dr
SmoothAirCruiser
The unlikely story of a flat tyre.
So I had that sad experience when I walked into the hanger the other day. A flat tyre. Sigh. The tyre had only just been replaced by my mechanic a few weeks (few flights) back in the annual inspection. Fortunately in the hanger, it is less painful that in the field. So I went through the...
www.vansairforce.net
kens_cockpit
Engine stopped
Only just worked up the courage to post this. Constructive comments welcome, particularly those directed at solutions. Keep the flamethrowers stored. About 1 month ago during Phase 1 testing. Top of the first ever stall turn. Left rudder. Yaw established. Throttle to idle. Propellor stops...
vansairforce.net
Ironflight
Hose Day!!
About a week before Airventure I sent Tom Swearengen a list of hoses I needed for the Rocket project (all except the oil cooler ones - haven’t mounted that yet, so don’t know the lengths), so I was excited when I got a box from TS Flightlines today - I guess he has gnomes building hoses while...
DonMcKee -014
Can I avoid machine countersinking this thin part?
I'm prepping parts for the W-00012 ADAHRS Mount Assembly to be used in my RV-14A wing: The instruction to machine countersink the 0.032" thick W-00012C Retainer for an AD4 rivet made me pause. I considered machine countersinking the underlying, and much thicker, W-00012B Mounting Spacer, and...
vansairforce.net
TheBoatLife
Empennage lower side skins fitment
I'm on page 10-14 and have the side skins cleco'd on. I used a roller tool several steps back and did a slight break on the edge of the skins before I dimpled them. Now that it's together the edge of the skin doesn't sit flush with the bottom skin. It's much more than a simple break would need...
vansairforce.net
Ironflight
How Hot the Pitot Line?
If you’ve got a heated pitot tube, it probably came with aluminum tubes for pitot and AoA installed into the body, and they were probably a foot or more long. At some point, you probably want to transition from the metal one to nylon, poly, or silicone tube, just because it’s easier to work...
vansairforce.net
Mothership
Order the RV-15 Kit - Van's Aircraft Total Performance RV Kit Planes
OFF TOPIC:
vansairforce.net
vansairforce.net
