The VAF News - 4.1.2025. #6309.
DeltaRomeo
doug reeves: unfluencer
Staff member
Tuesday Splash Images ….dr
….some pics from 52F Monday morning. RV-8 taking off seen in the car near the runway at 52F working on the laptop. Two minutes later Kay landed in his 8A and I got a pic taxiing nearby. Couple minutes later a -10. Busy RV morning at 52F <g>.
mhabib2011 7A
dr
olyolson RV-4
RE: Fuel Flow Issue after bad gas
…DanH reply
What Larry said, assuming you have a Bendix or AvStar. I've done at least one AOG rescue after a Bendix screen bypassed.
The red cube outlet is larger than the inlet. The inlet diameter is about 9/64", roughly half the ID of a -6 hose. Debris can stop up the inlet, but generally it would require rather large trash to do it. We've seen that in an accident involving silicone sealant, but rust that large seems unlikely downstream of strainers.
In any case, if you want to remove the red cube and flush it, you wont hurt it flushing both ways with clean fuel. I would not use compressed air, as it would spin the little plastic rotor too fast.
RE: Seat Rib Questions
…RV-9erA reply
Just for reference -- two photo attached from my RV-9A build between 2000 and 2004. When I'm working under the forward seat pans, I like to keep the floor-rib removable bridge sections in-place for added floor rib strength. I also sit back away from the forward ribs with a cushion or pillows, which prevents over stressing the forward floor ribs. These ribs don't have much strength without the removable bridge sections in place and the floor pans screwed down.
avatty RV-14
iO390
OFF TOPIC:
