WDYDWYRTW? Mar 21-22, 2026. Chuck Norris and more.
Flew the -6 Saturday morning in meat servo mode for .5 with a lazy pass by the former home of the late great Chuck Norris (lived there for a few years while filming Walker TX Ranger). Dipped a wing. North shore of Grapevine Lake. Rest in Peace, sir. Not a cloud in the state and 80*F -...
vansairforce.net
Eric Vickery’s RV-10 | Westcliffe, CO. RV-10 #42451
https://www.vansaircraft.com/first-flights/eric-vickerys-rv-10/
vansairforce.net
RV-14 Rudder Pedal Blocks
Impressed by the quality of some aluminium products out there, but not liking the cost (espcially with foreign conversion / postage issues / tariffs etc!), i decided to design and 3D print some of my own. Thought i would share here in case anyone else wants them. They can be downloaded here...
vansairforce.net
Update: Working on Hall trigger in the Slick housing. 3D print mockup parts...
Sensor is a 55505 from Littelfuse, which is under $30.
To meet sensor tooth size specs, the wheel is a 24-1
Open Source EI for Lycoming??
OK, sorry! I continue to spam this thread. For internal power... Gee, I yanked that big coil out of the SLICK magneto... If I put it back in... the unit already has a spinning magnet... The coil is 375uH if that helps anyone estimate how much power is available. Ideas are contributions -...
vansairforce.net
Rattlecan paint?
Got a small non-structural fairing to paint that the radio antennas attach top on top of/between the wings, white on bottom that has a feathered edge of black from the top. Used some Rustoleum Paint's Touch 2x ultracover (because Rustoleum is what Johnny Bench said to use!!), the white came out...
vansairforce.net
Adding to an older thread...
I have long suspected the o-ring on the shaft can allow the valve to suck air. A few weeks ago I was speaking with another VAF'er, whose experiments confirmed air leakage and bubble formation via a stem leak. So, I put a fix on my list of things to do at the next condition inspection.
Here it is. Not flown yet, but any future leakage is extremely unlikely.
Fuel Valve O-Ring
I had previously lubricated the standard Vans brass valve with a very thin film of EZ Turn. It was fine initially, but over time it became difficult, I think more so than a valve assembled dry. So, given its non-performance, coupled with the bad habit of clogging fuel controls, henceforth I'm...
vansairforce.net
Firewall Sheetmetal question
Had a nosewheel collapse and a prop strike. New nose wheel is getting replaced and as a precaution a new mount too. Needing guidance if it’s needed to redo the whole firewall skin or this can be repaired with a new cutout section with a row of additional rivets and doubler in a ‘U’ damaged...
vansairforce.net
I'm actually working with this part now. It goes on the inside of the doubler that goes over the carry thru spar. However, it has to get final drilled later in the process when the landing gear bracket is drilled. In this picture, it's clecoed to the inside.
Name that Part - RV-10 Style
I think the image attached is from the fuse kit, but I'm not sure. I thought it was F-1004T-L and F-1004T-R but cannot find such a part number in the plans (yet). Thanks, Mike
vansairforce.net
OFF TOPIC:
vansairforce.net
Past ‘VAF News’ issues:
www.vansairforce.net
vansairforce.net
