dr
johntwilcox
etocr
jaybob
mfleming
Milestone: First Engine Start
…cgeyman
Nashpdman
Technique …Nihon_Ni
Riveting bottom skins solo.
Here's how I did my RV8 wings solo. I was in the basement, so I clecoed a piece of scrap to the then, and used it to tied the skin to a rafter and adjusted it after each series of riveting in an L-pattern others have described above.
VS Help
…YME 12
glenadavis
Replaced brake pads - at correct torque it binds
I replaced my brake pads on my 6a. I fully returned the master cylinder all of the way. However, when I torqued the caliper bolts down all the way, the brakes grab the disk and do not spin. My mechanic told me this is common, and the solution is to slightly back off torque so it can spin.
Has anyone experienced this? Are there spacers I can get to make the caliper slightly wider and not grab the disk?
OFF TOPIC:
WDYDWYRTW? (12 / 21-22 / 2024)
...getting this weekend's thread started. No RV for me this weekend, as I'm working extra paper routes while people will use me during the Christmas season travel rush. We shared the ramp for a bit with a beautiful RV-7A in south Texas... ...and yesterday got the once every few months view...
vansairforce.net
johntwilcox
Do I dimple these too? F-823
Do I also dimple the “ leave open for flap fairing attach” holes?
vansairforce.net
etocr
My First Trailing-Edge…
Hi Gang, First-time builder and First-time poster. So here it goes… I’m fixin’ to close up my RV-14 rudder which leads to riveting the trailing-edge. (Yikes!) With cleco’s as fasteners, the trailing-edge is somewhat wavy. Will this straighten out during the riveting process? Also, between...
www.vansairforce.net
jaybob
Baggage tie downs - roll your own!
Ditched super horrible tie down rings on my RV-9A and went back to design used in -10 build. I think I bought them but the vendor is long gone and nothing online found (until now). - Tie downs fabricated using 4 pieces of .063x2x3" scrap (old panel), with two .75" holes in each - MS20257-4...
mfleming
Excitement on Climb Out (rough running engine)
Yesterday we had a bit of a break in the weather, so I decided to exercise the -7. All was normal with the run-up except the #2 cylinder was lagging behind the others in EGT/CHT. I've noticed this for a while but everything was running well so no action taken. The takeoff roll was normal as...
vansairforce.net
…cgeyman
First engine start
Hurray. Getting closer to DAR day. Cal https://share.icloud.com/photos/0b6DKz2kg4S_KjVt2-qcMnDgg
vansairforce.net
Nashpdman
Forward pushrod end bearing thread depth?
I've just completed the forward push rod, F-1089. I'm only getting 3/8" of thread depth on the rod bearings when I set it to 37-13/32" as referenced on pg 39-3 figure 3. This seems kind of shallow to me. Can anyone advise, is this normal? I've rechecked and verified the measurements (33" tube)...
vansairforce.net
Technique …Nihon_Ni
VS Help
…YME 12
Vertical Stabilizer help
Finally started my build when I ran into my first problem I finished clecoing the Vertical Stabilizer and called it a night. The next morning I noticed a small dimple on both sides of the skin where a rib (VS1202) is clecoed. It seems the rib in that area is too tight. I radiused the front...
vansairforce.net
glenadavis
Need advice re: canopy frame covers
My new to me 12 did not have the canopy frame covers installed. Although they were provided to me when I bought the plane about a month ago. I don’t have access to the build plans right now so I am asking here what’s involved in installing these? Are they screwed in or held in with adhesive? Are...
Howdy, I replaced my brake pads on my 6a. I fully returned the master cylinder all of the way. However, when I torqued the caliper bolts down all the way, the brakes grab the disk and do not spin. My mechanic told me this is common, and the solution is to slightly back off torque so it can...
OFF TOPIC:
vansairforce.net
vansairforce.net
