Wishing you and yours a happy, safe and RV-filled weekend. (sorry for the late push - part time sim ran late last night.)
v/r,dr
Paul D
fixnflyguy RE: Fuel primer pipe support
KEG RE: Need a 12 iS panel picture
How is this?
rockyfatcat RE: Reassemble RV7 from Shipping container - Houston / Southern TX area
There are bolts connecting the spar, flap, and aileron. Fuel lines and wires to the fuel tanks and wingtips. A pitot line and the wing to body fairing. Plus some reassembly of the interior removed to FOM
Scott Hersha RE: Your advice, please, soon to take delivery of an RV 4.
Load your charts on an iPad mini running any of the many e-flight bag setups, and put that on a knee board. No folding required, and most of the time you probably won’t even need that.
Or you can make a bracket to put it in a convenient spot. This one is in a relatively shaded spot on my former RV4, and talks to my uAvionix echo.
HFS
Steve N.
Jesse23
OFF TOPIC:
v/r,dr
Paul D
Recalcitrant Tanks Close-out Plate….Any Clever Ideas?
I’ve only spent a few days tinkering around with this, but it’s got me a bit stumped - maybe someone has a clever idea for a different attack! I have to remove one of the factory-installed tank close-outs on the F1 because this twenty-something year old tank (which has never had fuel in it, but...
vansairforce.net
I’m having trouble finding out how to support my primer pipes. I’m in the process of doing a top overhaul. As we put the engine back together I need to support the four primer pipes. 1/8” copper tubing routed along the push rod tubes. The original builder used a semi soft grey material...
vansairforce.net
How is this?
Could someone please post a wide picture of their RV-12iS with the Garmin avionics ((including autopilot head)) package? And then a second one showing the fuses? In anticipation of starting recurrent/transition training after 8 years away from flying, I'm trying to develop muscle memory with...
vansairforce.net
Trying to get an idea of cost to reassemble a RV-7 that would arrive in Houston in a shipping container after having been professionally disassembled and packaged in Europe. Feel free to call or text for a more detailed description / conversation. 801-201-9964
vansairforce.net
I will soon take delivery of an RV4 in good shape. Pre-Buy mechanic and former four-owner suggested a tail beacon x and maybe an autopilot for long cross-country flights. I would appreciate your thoughts on whether to consider an AV 20 or 30 to go with the tail beacon X (no transponder now) or...
vansairforce.net
HFS
EZ-PORT (Static) Revisited
I make a static port from a Hylok HL20PB6-2 fastener that offers the option, since the "shank" has a 10-32 thread, you can thread on several different tube type ends. In the pics attached you can see a hose barb, a push-to-connect 1/8 &1/4 connector - anything that can be internally threaded to...
vansairforce.net
Steve N.
FM150 cowl clearance issue
I have a Superior IO-360 parallel valve engine with a cold air sump and a FM 150 fuel servo. The bolt that holds the mixture arm to the servo and the arm itself is contacting the bottom of my RV-8 cowl. Anyone else have to deal with this problem?
vansairforce.net
Jesse23
Antisplataero oil separator, oil filter drain, Crankcase vaccum kit
I finally got around to installing the Crankcase Vacuum on my RV-10. It took quite a bit of customization to make the kit work with a Vetterman exhaust. Details and parts list can be found here: https://www.strikhedonia.com/installing-the-antisplataero-crankcase-vacuum-kit-on-an-rv-10/ I did...
www.vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
