Antisplataero oil separator, oil filter drain, Crankcase vaccum kit
I finally got around to installing the Crankcase Vacuum on my RV-10. It took quite a bit of customization to make the kit work with a Vetterman exhaust. Details and parts list can be found here: https://www.strikhedonia.com/installing-the-antisplataero-crankcase-vacuum-kit-on-an-rv-10/
I did as well along with the Oil seperator. I installed on the right side. I made 1” spacers for the OEM cross clamp and a threaded extender for the cable. It’s not pretty, but it works, and the clearance is fine. I sent a pic to Akan at Antisplat and he agreed the design wasn’t changed for the RV 10. He may make a smaller bracket for the clamps.
I did look at the right side for awhile. Much more room on that side...
