I need to mount a SkyView Primary ADAHRS Module in my RV6A.
Where did you install it ? Was a remote magnetometer required due to interference in that location? (Please post some pictures)
Can I use the RV7 adahrs mount that Van’s sells or it doesn’t fit in a RV6?
What is your experience mounting it in the Dynon tray behind the efis display? Do I still need a remote magnetometer ?
I would like to mount it in the front because it will be much easier to connect it to the pitot system and wire to the Dynon hub but I think the magnetometer won’t work well so close to the panel.
Thanks for your help
