aparchment
Doug:
I read your note below and was hoping for some more information.
You say that the Sony only displays 4 levels of color yet the specs say that it has an 8 level gray scale panel. I am by no means an expert on displays, but it sounds like you may have taken a look at an older model? Or perhaps I don't quite follow what an 8 level gray scale panel means.
Second, you note that some of the grays on the NACO charts may be mapped to white. Are you saying that they may not be mapped at all? I don't follow how a grayscale display can display white. Even if the case is that the grays are not mapped at all, isn't all critical info. on a NACO chart displayed in either black or dark gray? The only things I can think of off the top of my head that wouldn't display if light gray isn't visible are the outer rings of an NDB or perhaps the ramp or taxiways on an airport diagram. Can someone think of something else that is missing?
Antony
Antony
Paul,
I looked at the Sony eBook Reader long ago ... and determined that it was not
satisfactory for *my* purposes. I was curious what others thought about it,
so I kept my yap shut to avoid biasing the discussion.
The Sony & Kindle use the same screen ... both are limited to four [count'm 4]
levels of color (black, dark grey, light grey & white). NACO is authoring the plates
to use more levels - dunno how many. Hypothesis: Some of NACO's greys are
being mapped to white by the Sony.
> smoking your own computer ...
No problem. I was curious if the residential cablemodem (1.544Mbps upload cap) was
discouraging usage. It was ...
