Finally got the Wing Kit(minus the Spars) late last week. Delivery was ABF and they got it here in good time. All appeared in good shape on the exterior of the boxes. Until.... Things went a bit sideways(literally) when I opened the big wooden crate. The airline words, "Items in the overhead may shift during flight" came to mind. At some point there was enough side load on the main box to jar loose a few of the skins and parts; sideways. This bent and curled a few of the leading edges and tabs on the skins, in addition to busting open the box of over 7,000 blind rivets. There were hundreds of rivets on the bottom of the crate when I opened it up. One piece has deep surface scratches. In an odd twist, one of the leading edges has some light "veins" in it. This appears to be a manufacturing defect in the metal. Not sure.
Once past that, inventory started. I was supplied a hardware bin with fuel tank parts, but I have pre-built tanks. I am missing the entire Hardware Bin 1. Otherwise, I'm only short in one area for a few bolts. Someone got crazy with the Plate Cover's and I have double of those. There are a few other backordered items in addition to the spars but that will work out just fine. I completed inventory today and it's somewhat organized on the shelves. I have affectionately dubbed this area the "Come and Take It Parts Center". Ha! It's a Texas thing. The parts look to be in good shape overall. It will be interesting to see how the claim process works between ABF and Van's. There was a big side load(drop?) somewhere but the crate was in tact with no damage. Not sure how that happens. The tanks are in cardboard boxes instead of wood and I still need to get into those.
Next up is organizing the garage for the Tail Kit as it's coming this week. Lots of parts all at once and I'll probably prep and prime both of these kits at the same time. It's time to start peeling blue plastic...
