Hopefully an attempt to inform and dispel some common mis-information.
Rotax Myths
Rotax Myths
- Small boutique maker of engines. Actually BRP is a multi-national company with a 4-5 billion dollar market cap. BRP has produced over 7 million engines across their product lines for over 50 years. The aviation division has produced over 170,000 engines over the last 30 years. Who knows how many drone engines.
- Rotax doesn’t produce certified engines for certified aircraft. Rotax has produced certified engines for a number of airframes and continues to do so. Tecnam, Sling, Cubcrafters, and Van’s use certified engines in SLSA aircraft. There are several European plane manufacturers that use certified engines as well. The small c in the model name indicates a certified engine, e.g. 912isc Sport is the certified version of the 912is.
- Rotax engines are not reliable. Over the years of use, the track record for Rotax aviation engines has been found to be as good, if not better than other engines. The TBO for the 912 and 916 series is 2000 hours with many engines flying beyond that time period.
- Rotax is water cooled. In reality the 9xx series is a hybrid engine with the cylinder heads being water cooled and the cylinders being air cooled. As such, shock cooling is not a concern and CHT’s are much more consistent.
- If a Rotax looses all its coolant the engine quits. The engine is designed to handle such an event. With a power reduction the engine may safely be operated up 30 minutes with air cooling only. If the CHTs exceed the temp limit (temp and time) they need to have the hardness tested or the heads replaced. The engine doesn’t just overheat and seize up.
- There is no constant speed prop option. Though not common, all of the 9xx series engines can be equipped with an electric prop governor and variable pitch prop. External mounting pad is available for an additional alternator or vacuum pump. (Hydraulic CS prop setups are also available--Thanks to all that pointed this out)
- Don’t trust the electronics. Like legacy engines Rotax has redundant electrical systems. 2 generators, 2 regulators, 2 ECU units. Further, its has 2 ignition systems and dual fuel injectors per cylinder.
- No service is available. This is a valid complaint in many parts of the USA. Factory approved training is available but limited to a handful of locations. Frankly, the market for A&Ps to learn about Rotax has been stunted by the predominance of the engine in the EAB market. As more SLSA planes come into the market with Rotax engines, the market dynamic is anticipated to correct the shortage.
- I don’t trust an airplane with a gearbox or PSRU. Almost all helicopters have a transmission, otherwise known as a gearbox. Most turboprops with a PT6 engine have a gearbox. A320’s have a gearbox. Gearboxes are not inherently bad. Rotax gearboxes have a slipper clutch and a 30 degree ramp on the coupling from prop shaft to gearbox output shaft. This actually protects the engine during a prop strike and there are relatively simple tests to be done after a prop strike that does not require engine teardown.
- Parts are expensive. Compared to what? Not cheap, but comparable to other aircraft engine manufacturers. Most parts are available within weeks, not months or years.
- Rotax engines don’t use 100LL. Well they do, but the lead does shorten some service intervals. Decalin can be used but Rotax XPS oil has been developed to mitigate the lead effect without Decalin. Many owners try to use mogas but if not available, fly 100LL without problem.
