I don't know anything about the poweer settings, but I am considering a B6 for my plane as well. Hesitant due to the extra weight. Does the extra HP make up for that and then some? Why do you prefer the angle valve engine?I've been planning on the -A1B6 for my new -8, but have just located an -A1A. Identically configured, it's $20K cheaper. Is there any reason to be concerned with the power setting limitations of its non-counterweighted crank?
I prefer the angle valve chiefly for its HP advantage over the parallel valve engine. Between the -A1B6 and the -A1A (both angle valve engines), the HP is identical.I don't know anything about the poweer settings, but I am considering a B6 for my plane as well. Hesitant due to the extra weight. Does the extra HP make up for that and then some? Why do you prefer the angle valve engine?
I've had both parallel and angle valve. I personally prefer the angel valve due to piston squirters however nothing is free because you pay with increase oil temperature (easy to mitigate), however the Angle valve cylinders are more expensive.I don't know anything about the poweer settings, but I am considering a B6 for my plane as well. Hesitant due to the extra weight. Does the extra HP make up for that and then some? Why do you prefer the angle valve engine?
I hadn't ever considered the Whirlwind prop, but some quick research really favors the 330 with the -A1A. That might very well be the plan!Power setting limitation is dependent on which propeller you use. I have the IO-360 A1A in my RV-7 with the Whirlwind 330 propeller and love the combination. No power setting limitations but a personal preference to stay above 2250. Also you are saving some pretty substantial weight on the front end with non-counterweighted crank. In all fairness however, if you get the counterweighted crank and Whirlwind 300 propeller would probably be about equal in weight. Don't think you can go wrong with either option.
There is no power difference. The difference is that you could potentially use certain propellers without having an RPM restriction. The engines are the same except for the counterweighted crankshaft.I don't know anything about the poweer settings, but I am considering a B6 for my plane as well. Hesitant due to the extra weight. Does the extra HP make up for that and then some? Why do you prefer the angle valve engine?
Hey Jerry - Great to hear from you! Whirlwind says that there aren't any RPM restrictions with their prop. I'm very tempted to go with their 3-blade 330 model.Hey Ken! It depends on the prop. My old Hartzell has an RPM restriction with the A1A of avoid continuous operation at 2000-2350 RPM. This is never a problem because I’m usually in the 2400-2600 range. Best to check the TCDS (Type Certificate Data Sheet) for your intended prop. The TCDS lists engine/prop combinations. If it’s not a certificated prop, a TCDS likely doesn’t exist. You’ll have to consult with Whirlwind to see if there are any RPM restrictions if you intend to use that prop.
My bad. I am just learning about the engine letters and numbers, and I didn't know the A1A was not a parallel valve engine.There is no power difference. The difference is that you could potentially use certain propellers without having an RPM restriction. The engines are the same except for the counterweighted crankshaft.
No worries. Lycoming has decoding chart somewhere that explains all of the prefixes and suffixes. It’s hard to find.My bad. I am just learning about the engine letters and numbers, and I didn't know the A1A was not a parallel valve engine.
Hey Ken,Hey Jerry - Great to hear from you! Whirlwind says that there aren't any RPM restrictions with their prop. I'm very tempted to go with their 3-blade 330 model.
To be clear(er): other than max RPM, there are no known operating restrictions but determination of specific restrictions, or lack thereof, requires more testing than Whirlwind has completed.Whirlwind says that there aren't any RPM restrictions with their prop.
Fair enough; much appreciated.I'd recommend doing some reading of Hartzell Manual 193, Volume 1 and Volume 2: Section 4 in Volume 2 for general info and then Volume 1 for specific engine/prop combinations.
Cool; thanks! Sounds very good...Hey Ken,
Just another data point. I have the first Whirlwind 330-3 prototype that Whirlwind produced prior to open sells of the propeller and eventual sell to Hartzell. I've got about 600 hrs on the propeller now and had the 500 hr inspection completed prior to Jim selling the company. The propeller has amazing capability and one piece milled hub takes all the power pulses on the non counterweighted crank. No leaks in 600 hrs for what its worth. I think I did a write up 4 years ago that is somewhere on the site.
Hey Trevor,I'd recommend doing some reading of Hartzell Manual 193, Volume 1 and Volume 2: Section 4 in Volume 2 for general info and then Volume 1 for specific engine/prop combinations.
Lycoming sells a list of model numbers and the airplanes that used them. Probably not up to date but useful.No worries. Lycoming has decoding chart somewhere that explains all of the prefixes and suffixes. It’s hard to find.
