Garmin AXIS, Next Generation Integrated Flight Display
I have a question on GDU 80Px, from what I gather it has the same cutout and mounting holes as the GDU470.
Is the bezel overhang from the panel cutout the same as the GDU470
Just curious as I have cut my panel for a GDU470 but will now be fitting a GDU 80Px
Rob
Look at the introductory material when they announced this, but I believe it is the same height exactly top and bottom but an 8th inch wider on each side so a quarter inch wider in total
Rob
To add to that as I am in the same boat, I wonder if it will have the same bump on its right in the way the 11" display has.
Not sure how this will work in an RV-8. Need to get the tape measure out and see if I can fit it in with the required nav and com stuff.
At first glance I think it will. If the foot print is 11.6”.
I have the G3X, G5, Garmin audio panel, backup Garmin com (only) in my panel. It shoud fit easily.
Hey, Rob,
You will need exactly 1/8" more on both the left and right sides of the GDU 116. Too and bottom edges remain the same.
+Scott+
I had been told that the overall is 1/8" larger which makes it 1/16" on each side. Can you confirm it is is actually 1/8" on each side and a total of 1/4" overall side to side?
Looking for a recommendation as how to best handle the below situation with a 'B' screen as a PFD which only has 3 HSDB inputs.
I know what the manual says, but there are a few different ways to handle this, will one work better than the other?
Assuming weather traffic are shared across displays via HSDB is the connection to the PFD using HSDB just for redundancy?
(My G3X already has the serial connection for W/T from the 45R)
Panel builder is recommending a HSDB from the GTX-45R to the GTN Xi and not to the GDU' since the GTN has 4 HSDB's. Hopefully g3xpert can confirm.
It could be interpreted to that the opening is the same, but you need more clearance for the bezel itself on the panel surface.
I don't think it's a matter of interpretation. The panel cutout and the bolt pattern of the the Axis and the G3X are identical. The bezel of the Axis is most certainly wider than that of the G3X.
What's unclear is whether the Axis bezel is 1/8" larger on each side or .075" larger on each side. The manual states the bezel is 1/8" wider on each side:
But g3xpert previously posted:
The AXIS display's are 0.075" wider on each side. We apologize for the confusion on this aspect.
Pretty sure g3expert was referring to the 11" displays gdu 116. It's .15 wider overall, .075" on each side. I can confirm this as had a new panel cut to move it over from my G5 for clearance. I am not referring to the GDU 46x, I cannot comment on that unit.
Didn't you previously have GDU 460's in your panel?
Yes, g3xpert has written that the GDU 116 bezel is .075" wider than the GDU 460 bezel on each side.
The Axis installation manual states the GDU 116 bezel is 1/8" wider than the GDU 460 bezel on each side.
As Dmattmul pasted above, the drawings from the G3X Installation manual & the Axis installation manual support that the GDU 116 bezel is .15" wider overall than that of the GDU 460. In other words, the Axis manual is incorrect in stating that the GDU 116 bezel is 1/8" wider on each side.
Ya, But the pilot side insert contained a g3x and g5 butted up to each other. I had the left insert recut to move the g3x mounting holes to the right a bit so the additional 0.075 on the left side of the GDU 116 wouldn't overlap with the G5. Similar issue I guess to your two G3X units butted up against each other.
G3xpert - I realize Oshkosh is the priority at the moment, but I think there is some information missing about the dimensions of the panel. There's nothing to indicate where the main panel hole sits L-R relative to the mounting holes / nutplates. There's also no information on the external outline of the display relative to the holes (although it may be more reasonable to infer it is centered relative to the holes). Can we get an updated drawing and STEP files for the actual GDU116?
I did the upgrade today. All went smooth. No white smoke… and only had one issue. :)
Here is what I did and learned:
  • Power pins: Update to 4 power and round pins. This was not too bad, I just cut the original power slide and spliced the additional wires in. Maintained the backup battery on the PFD.
  • HSDB: Total of 3 new connections - PFD to MFD, PFD to GTN 750xi and MFD to GTN 750xi. This was not hard. Note: The two twisted pairs are TX&TX and RX&RX. Use a color system you can remember (or write down) for A vs. B.
  • Device ID: Remove the device ID strap from the PFD. I had to install an ID strap on the GRT200 to indicate to the CAN bus that it is COM2. The Axis display will simply show no CAN-BUS connection if not installed. This was not needed for the G3x Touch and frustrating to debug.
  • SW updates: The Axis SW includes the updates for several LRU, but the GTN 750xi. The GTN needs to be updated and configured following the Axis installation guide.
  • Setting up GEA24 inputs: All straight forward. One watch out is that the flap sensor settings are very different. The install manual has the details. Follow it.
  • Update/install new Config Module: Update the one in the PFD and install one in the MFD.
One question for @g3xpert : I have a GLD 50R that has a serial connection to both the PFD and MFD. The Axis device application only allows me to connect it to one display not both. There is not option (or I cannot find) it to add a 2n serial connection. This worked fine with the G3x Touch. Is this expected?
I would assume this is also required for GTR 20, which pins are involved in the ID strap?
I’m glad you asked. I assumed they were symmetrical but they may not be.
I dabble in parametric solid modeling. If something will be underconstrained, it's usually easy for me to spot. Where the hole is asymmetric, it's a safe bet that it needs to be specified by Garmin. Would love a solid STEP or SLDPRT file of the GDU116 to build with.
EDIT: and formally, drawings should be considered "not to scale" until/unless specified, but in this day and age it wouldn't surprise me if you could actually pixel-measure their undimensioned drawing to get a number that is close enough.
So if I already have a 750xi....is there a reason to go with the 11c (in my 182) vs the 11B and just get the gma 35r and 20r radio? Is that configuration not the same short of the second IFR nav source for a few thousand less?
I still think there’ll be a lot of that type of setup in exp and cert. (separate gps/116B). It’s a great setup as is 750xi/g3x. I see everything with wings getting a g3x with how many will flood the market, including both of mine.
One huge update I just noticed while reading the AXIS documentation is that when connected via HSDB, a GNX 375 now has VNAV capability! You can program this into your flight plan on the GNX and the AXIS with a GMC 500 series AP will fly it. This is a great update - thanks Garmin!
Oh, I saw an earlier post about the GDL 51; I also noted that the GDL 51R is supported in the installation manual, which is great to hear.
Another tidbit is that the connection kit listed in the experimental manual shows connection kits for G3X upgrades. However, the experimental upgrade kit is 010-14468-010, which is not listed in the IM. You do need one of these per display as it includes configuration module required for each.
Played around a bit with a 3-screen Axis panel in the Garmin tent today. It’s nice, but to be honest the upgrade in performance over the G3X Touch is kinda lost in the sauce to me at the moment since anything’s an upgrade to my 14-year old non-Touch G3X. My PFD (GDU 370) is on its last legs (soft key issues) so I’ll definitely be upgrading. I just now need to go to school on the LRUs and figure out what architecture (eg external IFR navigator or integrated, etc) I want to go with. But I have some time as I’m not financially ready to pull the trigger yet. That also lets you bleeding edge folks work all the bugs for me. 😜
