Emag/Pmag bearing play poll
Emag/Pmag users: How have your bearings held up? Make one selection per individual unit you've run
  • Run < 200 hrs, no bearing play detected
    Votes: 13 16.7%
  • Run 200-1000 hrs, no bearing play detected
    Votes: 46 59.0%
  • Run 1000-2000 hrs, no bearing play detected
    Votes: 10 12.8%
  • Run > 2000 hrs, no bearing play detected
    Votes: 1 1.3%
  • Bearing play at < 200 hrs
    Votes: 7 9.0%
  • Bearing play at 200-1000 hrs
    Votes: 9 11.5%
  • Bearing play at 1000-2000 hrs
    Votes: 0 0.0%
  • Bearing play at > 2000 hrs
    Votes: 1 1.3%
  • Total voters
    78
rv6n6r
With all the talk about bearing play in Emagair ignitions, I thought it might be worth a poll to help illuminate how much of an issue it is for people. Not scientific but perhaps it will give a better sense of things than the individual anecdotes. The poll allows for multiple responses for those with dual EI or multiple planes. Please only report your own aircraft.
Not meaningful without old and improved bearings data separated.
Thanks for the feedback. It's out there now, not so easy to change after votes have come in. In any case I would say it's still better than a bunch of scattered anecdotes.
Bearing play on 1 pMag and phase failure on the other, less than 70 hours. Board failure on one after that, another failed range check when hot 2 flights after "overhaul" at E-MAG Air, unknown failure on takeoff at 550 hours (haven't bothered to attempt repair).
Yes, the prop (Hartzell wide chord composite) has been balanced to 0.03 ips.
Condition Inspection just completed on my -9A (470 hrs)...no bearing end play on either pmag according to my mechanic.
I’ve sent probably half a dozen to Brad for bearing play. Have also seen a couple where the internal gen is weak or inop.
Send them in for warranty repair. They should cover repair if it failed that soon after work being done.
So, a couple of weeks and 66 votes so far.
First off, the percentages displayed are off, presumably because each person can make multiple choices. Consolidating the actual percentages yields:
- 80% of responses with no bearing play in all hour ranges. Most of those responses are in the 200-1000 hour range.
- 20% of responses with bearing play in all the hour ranges, most with mid to low hours.
So, not an insignificant number but it also doesn't account for whether newer units could be more reliable than older ones.
Conclusions? Nothing concrete as it's an unscientific poll with a lot of unknowns. I have two of them and still prefer them over magnetos, so for me it mainly reinforces the importance of doing the bearing play check at every condition inspection.
