Emag/Pmag bearing play poll
Emag/Pmag users: How have your bearings held up? Make one selection per individual unit you've run
  • Run < 200 hrs, no bearing play detected
    Votes: 7 20.6%
  • Run 200-1000 hrs, no bearing play detected
    Votes: 19 55.9%
  • Run 1000-2000 hrs, no bearing play detected
    Votes: 6 17.6%
  • Run > 2000 hrs, no bearing play detected
    Votes: 0 0.0%
  • Bearing play at < 200 hrs
    Votes: 4 11.8%
  • Bearing play at 200-1000 hrs
    Votes: 3 8.8%
  • Bearing play at 1000-2000 hrs
    Votes: 0 0.0%
  • Bearing play at > 2000 hrs
    Votes: 1 2.9%
  • Total voters
    34
rv6n6r
Sponsor
With all the talk about bearing play in Emagair ignitions, I thought it might be worth a poll to help illuminate how much of an issue it is for people. Not scientific but perhaps it will give a better sense of things than the individual anecdotes. The poll allows for multiple responses for those with dual EI or multiple planes. Please only report your own aircraft.
Not meaningful without old and improved bearings data separated.
Thanks for the feedback. It's out there now, not so easy to change after votes have come in. In any case I would say it's still better than a bunch of scattered anecdotes.
Bearing play on 1 pMag and phase failure on the other, less than 70 hours. Board failure on one after that, another failed range check when hot 2 flights after "overhaul" at E-MAG Air, unknown failure on takeoff at 550 hours (haven't bothered to attempt repair).
Yes, the prop (Hartzell wide chord composite) has been balanced to 0.03 ips.
