I have the factory built tanks. After hearing that some have had leaks in the factor built tanks, I decided to test mine.
In order to eliminate any potential leaks, I used AN6 gauge fittings on the two AN6 tank fittings. On the first, I mounded the Schrader valve. The second, a 0-5 psi gauge was installed. the two AN4 fittings were capped with AN caps. The fuel sump was plugged with a brass NPT plug. All NPT threads were sealed using loctite 567.
The fuel caps were adjusted and the o-rings lubed with Krytox.
The tank was then pressurized to 0.8 psi. The plans say no more than 1 psi.
The tank leaked down in about 24 hours.
Pressurized the tank again. This time, I went over ever rivet and every seam with Camco gas leak detector fluid. No bubbles at all. The tank leaked down in 24 hours.
Next, I transferred the AN fittings to the right tank and performed the exact same process. Tank leaked down in 24 hours...basically the same rate as the left tank.
I have sprayed all of the AN fittings, the valve, and the gauge...no bubbles.
I am at a loss, and two days wasted.
Didn't have this much trouble with the -10 tanks...
The worst part was looking at the "inspected by" stickers, while the tanks leaked down.
So, has everyone tested their tanks? What are you seeing?
