GTN650 and Garmin Pilot Flight Plan Issue
CodyS
I'm New Here
After the most recent Garmin Pilot update it seems I'm now unable to load flight plans from a GTN650 to Garmin Pilot. Just get prompted to activate an empty flight plan regardless of what's loaded/active on the GTN.
Anyone else with the same setup with the same experience? Didn't have any problems prior to the update.
I'm having the exact same problem. It's extremely annoying. It WILL transfer if you activate a "direct to" on the GTN - that gets to the GTN 650. But if you set up a flight plan in the GTN 650, it does not transfer back to Garmin Pilot, automatically or manually. I'm about to open a ticket with Garmin about it.
I emailed their support prior to this thread creation. Was told that I was utilizing flight planning all wrong.... then later informed that there was in fact an issue.
Now resolved with 26.5.1
