I am installing a Plenum system on my RV-8 to maximize the airflow through my engine cylinders. I have spent hours sealing the high pressure area (top of the cylinders) so cooling air is forced down through the cylinder fins.
The cabin heat supply air duct is currently on the back wall of the high pressure section above the cylinders. Question, Won't this steal cooling air from the high pressure section and lessen the amount of air being push through the cylinder fins? Is the a better place to mount the heater air intake duct? Or, should I install a valve on the current heater air duct so it can be closed on hot days? And, if I do this will it damage my heat exchange shroud by cutting off the air?
