Recently I had a good exchange with the Hartzell pMag program lead. Some highlights (my summary):
- Emags are currently under active review by Hartzell Engineering. The approach is intentionally slow and methodical, with changes only implemented after thorough testing.
- While the sale of Emag occurred in April 2025, the planned transition of engineering and production responsibilities has always been set for January 2026. Due to staffing constraints in Azle, Hartzell began assisting with customer service in late 2025.
- Several engineering improvements have been implemented, including standardizing the tolerances of the rotor bearing bores and implementing new tooling to properly space the hall‑effect sensor from the magnet.
- Hartzell is conducting ongoing testing related to operating temperatures. Although data gathering is ongoing, blast tubes will likely remain a recommended practice. Experimental aircraft vary widely in cowling design, airflow, installation orientation (pusher vs. puller), and other environmental factors, making operating temp more of an unknown than in the certified market. The thought is, just like traditional aircraft alternators, cooling fans and/or blast tubes can improve the life of the component.
- Regarding the 200‑degree installation guidance: it is an operational limit, not a hard failure threshold. However, because end‑user installations differ so much there is no guarantee what temperatures a given aircraft will see without supplemental cooling. But the most likely time to see this color change would be after shut down during a heat soak.
- The single temperature sticker is a fair criticism. We are evaluating options, including multi‑stage temperature indicators similar to the ones I recommended.
- When posting pMag problems on the various RV threads Hartzell would appreciate the OP listing the associated pMag serial numbers. The point here is a “new” pMag may be several iterations old. The serial number will go a long way to identify a new issue vs an already identified (with and update) problem with a “new/old stock” pMag.
- Most common repairs
- Typical hours on pMags sent in for work
- 100hr (now 500hr) bearing wear checks - how many fail?
