RV9A demand
Rv9A
What’s everyone’s view on the market for 9A projects. Mission has changed and debating what to do with current project.
Depends on how the prop strike was handled.. SB475 or SB533 completed? No neither?
Engine (lycoming) was fully overhauled, unsure if they rebuilt with old case or not. Refurbished prop. Seller says damage to the main landing gear was fully rebuilt
BTW: I’m looking for a 9A tip up kit or plane. :)
Hi Mike,
At the urging of my wife, I'm considering putting my tip-up RV-9A project on the market as artheritis and age are making climbing up and down from a low winged aircraft somewhat difficult. Wings and empenage are complete and epoxy primed. Lower portion of the fuselage is pretty far along, but I am replacing two frames and some riveting I was unhappy with. I had intended to use a rotary engine in it so I have a Bruce Turrentine professionaly converted, zero-time, Mazda 2 Rotor 13B engine, RWS ECU, engne mount, RWS RD-1C PSRU, custom built aluminum cooling components, additional 13b engines (for spares), a digital TruTrack ADI Pilot II autopilot (new, never mounted), a James Rotary Cowl, two props available (1 wood & 1 aluminum), and several spinners to accomodate prop choice. I also have a bunch of aviation tools purchased for building the project that will also become available once a decision to sell is finalized and if it provokes enough interest.
Regards,
Jack
Hi Mike,
Regards,
Jack
That looks like an MT prop, which is worth selling separately for several thousand. There isn't really a market for the 13b itself, you might be able to sell it for a little bit on barnstormers. It's a pretty hard sell for people to buy an auto conversion RV, we've reached a point where the lycoming is the most valuable part of the plane.
