Scott ; the Unimatic line from Howmet exceeds the specs of the LP4-3 and comes in a length -2 or -3 that likely would work. They are not "max" rivets.Thanks
I have looked at them and I am pretty sure the min. grip of .126" for the -3 size is too large for rivets used for attaching skins to the wing spar flanges (but I don't have a kit yet so have not confirmed that).
Doesn't matter though, because if you try and buy any it shows "No Stock" in your cart like it does for all of the other relevant sizes of Cherrymax.
Howmet part number SMLS100-B04-02 or -03. Again the issue appears to quantity required to buy, but 1000 divided amongst 4 builders might be doable. This line are flat 100 degree heads .125 nominal diameter aluminum with steel locking mandrel. Another option may be Avdel Avex 01604-00414 Multi-Grip Blind Rivet; 1/8 Inch (0.125 Inch), (0.155 - 0.312 Inch Grip) . Its a multi-grip flat head with specs (S=165 T=230) essentially identical to the LP4-3 (S=162 T=236) and stronger than the CS4. Plenty of those around for 9 cents each.
