Curious what others are doing for the “QB” fuel tanks shipped with the kits.
The KAI say to flush with avgas (against my better judgement I did this on the L tank, and I think it was a waste of time and not worth the hassle/mess/risk. I filtered thru a coffee filter and basically got nothing. Won’t be doing it on the R tank). They then have you close the inspection panels and install the fuel sender, then leak / pressure test.
I watched the video from a few weeks ago where they talked about the commercial tank tester at the factory. So, in my mind, repeat leak testing is mainly to check our install of the cover plates and sender. I am not ready to close up the tank quite yet. I’ve done enough proseal work that I’m not super worried about closing the tank.
I just clecoed the main spar to the wing assembly. Once I rivet this, access to a lot of the tank is gone. Now I am scratching my head about doing a leak test before closing off the tank further.
What are others planning?
