I am working on an RV-12is with a leaky fuel tank. I was able to see the leak with some bubble solution and light pressure. The leak is coming from somewhere in the long seam that joins the top and bottom skins, on the rear-bottom side of the tank. I was kind of hoping that the leak was coming from the plate with the fittings or mount, but unfortunately it is coming from the seam.
So far I think my best shot at this repair is to remove the sender plate and try to re-seal that seam with a bead of sealant on the inside. I'd love to hear any other ideas.
