I hadn't considered the dynamic-dynamics of the tire -vs- stable-constant mass distribution within a rotor. Good point.Balance is always two planes for best result, but the rpm is not the rated or max. Turbocharger wheels are balanced on the same type machine and it would be impossible to spin them anywhere near operating speeds due to the power required. I dont know what the machines are but i have had and see many turbocharger wheels and they worked fine in operation. The compressor is balanced with two planes separately from the turbine wheel with integral shaft.
Wheels with tires are a different matter relative to the RPM. It is common that internal belt separations and other weird expansion shapes of the tire take place at speed. My professor in engineering worked for a famous tire company and while working on a problem had 100 tires x-rayed. Not a single tire had the belt aligned in the fused tire. Funny, said I, I never found one that was close to being balanced and recommended customers use another brand. Not so with metal parts.
So - all things being equal - Care to hazzard a guess as to why the B&C rotors have sooooo much more work done -vs- the Plane Power/Unipoint?
