This is the wire bundle for my two stick grips. After two years of flying I had a failure with down trim on my pilot stick. Zoom way in on pic and you will see where I nicked 2 wires when I built it. I cut the outer jacket with a razor blade and obviously pushed too hard. 2 years later the shield wiggled in a way to ground out that signal wire through that tiny crack. I had heat shrink over this and it took 2 years for the shield to wiggle into that crack. Thought I would post this as a lesson learned. I have the g3x set up to ignore trim switch activations after 5 seconds so no runaway trim issues.
If anyone has a better way to trim outside jacket I’m all ears…
