Thanks - I could not find where it specified the thickness!In the last year or so of inspecting RV's I've found a couple of them without this SB completed. Be sure to use the heavier .040 lock wire. I found one airplane with the lockwire added, but it was the thinner .032 wire and it had snapped apart.
It seems to me the rotation of the shaft would tend to put a loosening force on the lock wired nut. You should still have the drilled hole in the shaft to lock wire either to the nut or to the bolt as per the SB.I used one of these drilled jam nuts. Much easier than the method in the SB. The fellow doing my final inspection (retired airline mechanic and RV builder) really liked it and signed off the inspection so thats good enough for me haha. I know this isnt as per the SB so its up to you if you're comphortable with it or not.
NAS1423 Drilled Hex Nuts - LH And Rh | Aircraft Spruce Canada
NAS1423 Drilled Hex Nuts - LH And Rh Material - 4130 Alloy Steel Per AMS-S-6758www.aircraftspruce.ca
@rv6builder , What size nut did you order for this?I used one of these drilled jam nuts. Much easier than the method in the SB. The fellow doing my final inspection (retired airline mechanic and RV builder) really liked it and signed off the inspection so thats good enough for me haha. I know this isnt as per the SB so its up to you if you're comphortable with it or not.
I'm installing one of these right now. Really looking forward to putting it through its paces.Or replace with something better, I have one of these sitting on my bench waiting to be installed.
https://phaviation.com/products/product-category/the-pha-01-replacement-for-vans-flap-motor/
As others have already mentioned, safety wiring just the jam nut does not attain the same level of security as the SB method does.
If builders choose to do something different, it is important that they first develop an understanding of what is being accomplished with the recommended process so they can be sure of getting an equivalent result.
