My experience, to the letter. I have the extra check valve, and remove coking at every oil change as well.I have the whole kit and it seems to work as advertised. I do check the valve for coking at every oil change...
Answer from ChatGPT
reducing the blow-by of combustion gases into the crankcase
Possibly no, pulling a vacuum in the crankcase may help piston rings seal better. I say “may” because in drag race engines, they’ll use super low tension rings and the vacuum helps them seal, similar to gas ports or the L shaped dykes ring. Our aircraft engines don’t use low tension ring or thinner ring packs, so we really don’t gain all these HP benefits. I like my AS oil separator setup with the crankcase evacuating setup, no more annoying oil leaks!Overall, ChatGPT's answer is in line with everything I've read today about these systems. ... Except that one part. As I understand it, "blow-by of combustion gases" would be from the combustion chamber to the case. So creating a vacuum in the case should increase the blow-by, not decrease it. No?
I have the same and have found some minor coking at the last annual. Probably around 200 hrs since I installed the system.I have the whole kit and it seems to work as advertised. I do check the valve for coking at every oil change...
Ditto. Keeps the belly clean, but I'd be hard pressed to cite any performance improvement. And it stopped the small amount of typical Lycoming oil seepage in various places.I have the whole kit and it seems to work as advertised. I do check the valve for coking at every oil change...
but it calls for attaching an output hose from the dehydrator to the oil breather tube (dump line) which I don’t have since this line is mounted to the exhaust. Any thoughts?
Oh, forget that. What was I thinking? The answer is so much simpler: Get a larger rubber stopper and connect to the end of the exhaust tube. So the closed-loop dehydrator pushes air into the oil filter neck and pulls air from the exhaust tube where the vacuum check valve is installed.For a closed-loop dehydrator, I was thinking maybe adding another "tee". This way, in theory, the dehydrator is not increasing the pressure in the crankcase, and therefore no risk of popping that relief valve. I'd probably route the line over to the oil filler door so the dehydrator's inlet and return can be connected side-by-side. But it would need a cap, ...
I'm emailing them today. You've got me intrigued now.This may require a call to AntiSplatAero, to ask how many PSI it takes to push air through the check valve.
I was thinking that was the correct answer also. I looked at the crankcase vacuum kit installation instructions and it only deals with the oil separator/vacuum kit but not the vacuum kit alone. So, how do the instructions get modified and does anyone want to sell the crankcase vacuum kit they aren't using? I'm tired of chasing oil leaks.Oh, forget that. What was I thinking? The answer is so much simpler: Get a larger rubber stopper and connect to the end of the exhaust tube. So the closed-loop dehydrator pushes air into the oil filter neck and pulls air from the exhaust tube where the vacuum check valve is installed.
You may have a hard time trying to find an unused vacuum kit; I have not yet seen any unhappy customer.I was thinking that was the correct answer also. I looked at the crankcase vacuum kit installation instructions and it only deals with the oil separator/vacuum kit but not the vacuum kit alone. So, how do the instructions get modified and does anyone want to sell the crankcase vacuum kit they aren't using? I'm tired of chasing oil leaks.
I have a new one in the box that I will never use.You may have a hard time trying to find an unused vacuum kit; I have not yet seen any unhappy customer.![]()
1 qt every 100 hours? Wow. Even 1 qt every 25 hours is impressive, I'd say.+1 for the ASA crankcase vacuum system. Oil loss per 50 hours is now less than 1/2 quart, compared to 2 qt loss.
Clean belly, too!
It’s just that the gauges we have access to would be unable to capture a reading with the engine pulses, even if there is a slight vacuum, which there should be.Someone else can confirm, but I believe there are slight vacuum pulses - during the exhaust stroke, the exhaust gases escape the cylinder very quickly. This creates a high-speed pulse moving down the header tube. The low pressure behind the exhaust pulse creates a vacuum effect.
I’d put another valve on the other exhaust and ‘T’ them to the check valve, before adding a pump. I don’t think there’s really a need to go there. Race cars are high rpm, whereas Lycomings are low rpm and looser tolerances.I have been told that on race cars they actually put a vacuum pump on the crankcase ventilation. Has that ever been done, to anyone's knowledge, on a Lycoming engine?
We have a Mojave System set up on an O-320 with the ASA vacuum system. A tee was installed in the line between the crankcase and oil separator. The port is plugged when not using the dehydrator. I have not done testing with the instrumentation for temp and humidity but appears to be working.I have the same and have found some minor coking at the last annual. Probably around 200 hrs since I installed the system.
On another note- I have been considering an engine dehydrator from Red Baron Aviation, http://www.rbaviation.com/mojave/ but it calls for attaching an output hose from the dehydrator to the oil breather tube (dump line) which I don’t have since this line is mounted to the exhaust. Any thoughts?
This is strange, as already mentioned, this feature is one thing they advertise. But experiential evidence: This was one of the features I installed their system for. I have a Lyc 390 which despite its only 500 hr since new is a typical Lyc that marks its territory, seeping just a bit at the front of the oil pan gasket and front lower case part line. Since the installation of the AntiSplat system, this has stopped completely - completely dry, so there must be something to the vacuum.And yet, when I asked them that directly, they said there is almost no vacuum created by the Venturi effect.
^^^^^^^^I have the whole kit and it seems to work as advertised. I do check the valve for coking at every oil change...
Richard,I have zero oil on the belly since installation but I do get what I’d call a moderate amount of coking.
This is the latest clean. Was about 38h. I usually change oil every 25-30 but this time went a little longer.
They mandate max 50h between cleans. I certainly wouldn’t push that. Some installs may need shorter intervals.
Yes. That’s correct.Richard,
Is that what you get after only 38 hours since your last cleaning?
I ask because I never get close to that level of depositing. If anything, I get a little fine grey ash.
I have both Anri splat products. Connect clean air going into oil fill. Install a plug into each exhaust pipe with a ‘T’ connection line to the air pump. Now, you have a fairly closed system of recirculating dry air.I have the same and have found some minor coking at the last annual. Probably around 200 hrs since I installed the system.
Richard,Yes. That’s correct.
It would be good to know what others see as well.
I guess it depends on how well the separator is working - temperatures etc. Nothing unusual about my install. As per ASA.
Sounds like we are the same. Yes it’s plumbed back to the case and run almost exclusively LOP iaw Mikes red box / Deakins red fin.Richard,
Follow-up questions:
- Do you have the return line connected from the oil/air separator to the engine case?
- Do you usually run substantially rich of peak? (Not sure that would matter but I am curious.)
For reference:
- To be clear, I DO have the Anti-Splat separator, exhaust valve, and bypass valve installed (ie, the "works").
- I DO have the return line connected from the oil/air separator to the engine case?
- I do NOT run full rich other than for takeoff and landing. Otherwise, I run in accordance with Mike Busch's 'red box' brainology. (PS: That's a word).
Bottom line: I'd really like to know why you have such high deposits. Until you sort it out, I recommend you DO NOT skip a cleaning. If that bypass valve closes up with deposits, you run the risk of over-pressurizing the case. That is discussed in other VAF posts, and none of them are good.
I find that anywhere between 8-10 quarts is fine for my bird; it just isn’t using much oil…For the RV 10, unless you need some extra cooling with oil, 66% of 12 = 8 qts is all that you need. Add your 12.8 oz of Camguard if you use that additive and using Aeroshell 100W or something else compatible. I let it go below 7, then add a full qt vs topping off.
I get a little less than that in 50 hours, I clean it out on every oil change.I have zero oil on the belly since installation but I do get what I’d call a moderate amount of coking.
I use a loose-fitting wire brush in a drill, takes a few seconds. I don't ever see any real hard deposits that don't come clean, it usually just knocks right out.What are you using to clean the evac 1 way valve- brakeclean?
I agree with Carl, I'm not comfortable returning the separated oil back to my precious crankcase. I would much rather toss that small quantity of oil and replace with newI use the AntiSplat air/oil separator only on the RV-10s. I use the $100 separator from ACS on the RV- 8A and RV-8. None use crankcase vacuum and the oil from the separator is collected in a small can, not returned to the engine.
My thinking:
- While properly maintained the crankcase vacuum approach should be fine, but I consider the added stuff and added worry to not be worth it.
- Many will argue that returning the oil to the engine is fine. I however like the fact that at every oil change (or annual once oil use is known) I can check how much oil is blowing by. I consider this an early warning indicator. I collect perhaps 4-6 oz of oil in the can a year.
- I still direct the output of the separator to the top of an exhaust pipe. This provides another indicator if something is amiss;.
- This approach results in a clean belly - the principal objective.
Same hereI use a loose-fitting wire brush in a drill, takes a few seconds. I don't ever see any real hard deposits that don't come clean, it usually just knocks right out.
