Super basic question - I am using wire mounts glued to the skin to take wires back to the tail. Since there are only a few wires going to the very back, the diameter of the "bundle" is pretty small. When I zip tie the wires to the mounts there is still some wiggle room because the base where the tie goes through is a little wider than the wires. For these situations, do I need to wrap the wires with something to increase the diameter so the zip tie can actually grab on to them and hold them solid? I have smaller mounts, but I prefer the larger adhesive surface area of the bigger mounts.
