Whelen Strobe lights Power Supply
Most of them are in the trash where this unit belongs. Switch to led :)
Agree completely. And the goods new is the changeover is easy. Hardest part is taking out some flooring to get at the power supply. So remove the power supply. There are five wires going out to the wingtip with the old Whelen nav/strobes. You only need 4 for the LEDs and that includes the sync wire. Splice the wires under the floor in the appropriate manner (it's not hard, after all, I did it). Your done, you don't even need to change any switches.
I've still got a whelan power supply if anyone needs it. But agree that LED is the way to go.
Agree with others, LED technology has overtaken xenon flash tubes, at lower cost. But if you want to look inside, remember those capacitors can store high voltages for some time. Don’t assume anything, carefully discharge (use an insulated ground wire) the capacitors before anything else.
