John Clark
tomcostanza said:Example:
Active runway is 27. Left-hand pattern. I'm approaching from the north. Do I:
1) Enter the pattern on downwind at a 45 from the north?
2) Enter the pattern on crosswind from the north?
3) Overfly the field (what altitude?), descend south of the field, and enter downwind on a 45 from the south?
4) Something else?
Let's see if I can give you a few views on this. First, there is no "one size fits all" answer to your questions. Local rules, noise abatement, and terrain all play into the answer. Assuming that the example airport is on flat ground with no restrictions, I would offer the following;
1) If you enter a 45 from the north you will be making right traffic in your example. So, lets go to your example 3. I would do this for several reasons. Overflying the airport gives you a chance to look at the wind (if there isn't an ASOS or airport advisory available) ans check for traffic. A thousand feet above the published traffic pattern altitude is fine. Cross above the airport, get clear of the pattern on the south side, decend and reverse course into a 45 entry for 27. A crosswind entry will work, but it puts you in the path of departing traffic.
There is no such thing as an "uncontrolled" airport, they are
pilot controlled. Many times a "pilot controlled" airport can be much more efficient than dealing with ATC. The trick is to keep your head on a swivel, communicate, and be willing to negotiate a little.
John Clark, ATP CFI
RV8 N18U "Sunshine"
KSBA
