Got a bunch of ground wires from various avionics pieces running to a terminal strip, all individually under 7 amp draw, then to a larger ground stud between the engine -> battery negative. (SeaRey airframe is aluminum and cannot be used as a ground.) Just want to double check that-to a point- the ground wire size does not matter, I was going to use a 16ga wire from the terminal strip to the stud, about 30" away.
Thoughts?
Thoughts?
