hi
I am trying to order the finishing kit from Vans for my RV7A. I also decided to go with Sam James Cowl. I got the packing list from VAns. Not sure what i should omit and I need help. Do i omit the whole 7A COWL KIT IO-360 SubKit? which contains all of this below? I am going with superior IO360, horizontal induction, parallel valve, Dynafocal I.
________ 1.00 BAG 923-1 COWL HDWRE
________ 1.00 BAG 1953 AN426AD3-4
________ 1.00 COWL,7/7A BOT. IO-360 BOTTOM COWL PRE PREG
________ 1.00 COWL,7/7A TOP IO-360 COWL TOP PRE-PREG
________ 1.00 COWL,8 INLET LEFT INLET LEFT PRE PREG
________ 1.00 COWL,8 INLET RIGHT INLET RIGHT PRE PREG
________ 1.00 COWL, 6/6A OIL DOOR PRE-PREG OIL DOOR 7,9
________ 1.00 AN257-P3X6' HINGE X 6'
________ 1.00 U-720A UPR.AIR OUTLET BRACE
________ 1.00 U-720B LWR.AIR OUTLET BRACE
________ 1.00 U-620B BRACE
________ 1.00 AS3-063X2 3/8X6 1/2 ALUM SHEET U-621
________ 1.00 AS3-032X1 1/4X7 ALUM SHEET U-620D
________ 1.00 AS3-063X1 5/16X7 ALUM STRIP U-620C
________ 2.00 SSP-090X6' STAINLESS STEEL PIN
________ 2.00 SSP-120X6' STAINLESS STEEL PIN
________ 1.00 HINGE PIANO 1/8X9' ML
________ 1.00 BAG 1954 AN426AD3-4.5
Ths for your help
Ths for your help
