Just had a blowout and need to replace tires and tubes. The originals are 15x600-6 but acs shows the 600-6 to be larger? Which tires are being used to replace? Original is Airtrac.
I used a few desser retreads and finally settled for Wilkerson tires. Less expensive and to date far more balanced and better tires than any monster previously used.
Family owned and great to work with.
If you can’t tell. Highly recommend.
Ordered Michelin airstop from desser but see they are not 90 deg valve stems, they say only aero classic has the 90 deg stem for mains. Anyone found other 15x600-6 tubes with the angled stem?
