Wishing you and yours a happy, safe and RV-filled weekend!
v/r,dr
lucaperazzolli
vansairforce.net
bertschb
vansairforce.net
Q: Where did you mount the GEA 24 engine monitor?
A: Behind the GMC 507, since it's so slim and there's plenty of space available in the back, I took advantage of that space to place the GEA 24 and the GAD 29.
…Here is a photo of how my panel is coming along, although you can't see the GEA 24. When I get back to my workshop, I'll take some photos where you can see it clearly. I'm also sharing some images of the 3D custom avionics rack.
John G
vansairforce.net
A: (resrob66)
kookaburra
vansairforce.net
OFF TOPIC:
v/r,dr
lucaperazzolli
FFi Yearly Reunion in Trento (Italy)
Hi VAF ! Last week-end I spend three days with the RV-Pilots group enjoying formation flight in FFi RV standard. Here I was as safety pilot into the white and gray RV-8 well built by Luigi, Leo took this photo from my buddy RV-8 (franz) that worked as photoship. We started the FFi adventure in...
bertschb
Having trouble flaring fuel vent line
I'm using a flaring tool for the first time on my fuel tank vent line and I don't like the results. After eight attempts with the same results I'm getting pretty frustrated. I'm using a new Ridgid Model 377 flaring tool. The instructions say "Once the clutch releases, turn the handle at least...
John G
Showplanes canopy center latch
This is about the center latch on my Showplanes fastback canopy. It differs from the front and rear latches in that the latching rod is short, so it changes entry angle more than the front or rear latches do. When I lubricated the latch several months ago, it operated smoothly. I don't...
kookaburra
Carb heat
Hi everyone, New RV7a owner here and still a beginner with building and maintenance. I am to add the carb heat attachment in this photo with the duct flange and Exhaust Heat Muff attached to the FAB. The RV I bought doesn't have this and it's from 2010, but I couldn't find any references to...
OFF TOPIC:
www.vansairforce.net
vansairforce.net
