Our friend Paul wrote a nice piece on AvBrief on the passing of Jim Lovell. I suspect you’ll enjoy it.
Hope you had a nice weekend.
v/r,dr
dr
Blittleton
ColoradoSolar ….To The Airport (10)
RE: RV-12iS Fuel Pumps Not Automatically Shutting Down After Engine Shutdown
…Bob Y
If your HIC has the aluminum wire-harness support bracket, it’s the -2 version. It also has the diagnostic LED Tony mentioned earlier. If you have convenient access to the LED, you might try, as Tony suggested, to see what color it is after shutting down. I’m going to figure a way to do that with mine.
J-Dub Slider Frame Progress
Slow progress but I find myself in a bit of a pickle. I am pretty happy with the frame shape but when I try to slide it open the rear bows touch the aft skin. The obvious solution is to open up the bows but then when closed the lower skirt would be a ways away from the fuselage side skin. I am tempted to leave it and put Chaffe tape on after paint. Anyone have a better idea?
MacCool 9A
JDBoston 14
DrillBit Update on Engine power loss forces off-field landing: builder/maintainer error
Updating and closing out the saga: happy to report wing reattachment and landing gear fairing repairs are complete and 748PK flies once more. Truly amazing how well the engine runs when it can breathe.
On the bottom of the FAB, I went with thin 0.020 Al sheet, epoxied and riveted, then one one layer of Kevlar twill lamination over it, then leveled the FAB and poured a layer of white-tinted epoxy, forming a smooth surface for the filter to seal against. Every bit of "interior" hardware sealed away. When and if the filter starts fretting the epoxy again, I'll see how well the Kevlar layer below holds up.
jonbo 8A
bt3vex
Rest of today's edition in the next post.....
v/r,dr
dr
WDYDWYRTW? Aug 9-10, 2025
What did you do with your RV this weekend? Here's the activity at 8 AM Dallas Fort Worth time Sunday morning, August 10
www.vansairforce.net
Blittleton
UPDATE -- RV-7 engine failure, Emer landing, no damage/injuries
Flying from Winslow Az (KINW) to levelland tx KLLN), fat, dumb, and happy at 9500’. Suddenly out of nowhere (and over nowhere) engine rolled back. Mix, prop, throttle forward, aux pump on, and no power. Engine never stopped rotating, so I should have pulled prop aft. Made the call to center...
vansairforce.net
To the Airport
I got the plane moved to the airport. I live on dirt roads that have plenty of washboards so I drove very slow and was nervous the whole way even though the plane was securely strapped down. Got it tucked in next to its little brother (which is going to be for sale soon). Brought the wings out...
vansairforce.net
…Bob Y
After getting nowhere with Van's support on this subject (they wanted me to tell them how the fuel pumps shut off), I'll reach out to the group to see if any other 12iS owners have experienced their fuel pumps continuing to run after engine shutdown. Yes, I have implemented SB-00058 for the new...
vansairforce.net
Slider frame height......
Afternoon all, So I have done some searching and plenty of reading re canopy and frame set up. From all that I have been able to gather, the front height of the slider frame is always set after the plexi is installed. Can someone provide as succinct answer as to why? The plans clearly show a...
vansairforce.net
MacCool 9A
Getting rid of the gascolator....plumbing question
My RV-9A with IO320-D1A has a gascolator. My under-cowl temps run a bit hot, which manifests primarily as hard hot-restarts (not impossible, just a bit complicated). I have rigid un-insulated tubing coming out of the fuel selector to the gascolator then across the firewall to the red cube then...
vansairforce.net
JDBoston 14
Upper rudder fairing skin crack
Because apparently it is a rule that stupid things happen late at night I ended up cracking the thin rudder skin last night while trying to get the faring to be where it didn’t want to be(truth be told it was because I tried to remove it with that last cleco still in) Is this repairable...
vansairforce.net
The pilot in this story achieved perhaps a best-possible outcome, but the aircraft owner, builder, and maintainer chose poorly, to say the least. They are all one and the same person--namely me. Comes now the penitent, seeking the solace of public confession in the Chapel of VAF. On Saturday...
vansairforce.net
jonbo 8A
RV-8A Jonbo
Jonbo's RV-8/A Hi Folks. I started this build a couple years ago after finishing the practice kits and toolbox. Then I moved and put it on hold now I'm starting again. Workspace We put some nice lighting in and started getting tools setup. We coated the floor to make it a nice space but sadly...
vansairforce.net
bt3vex
Loss of Power - Forced Landing
I just wanted to share my recent story of my Forced Landing. All things considered you can technically call it a "Soft Field Landing". So I am 60 hours into my plane, which has an IO320, EFII System 32 set up. This things runs smooth and starts like a car almost unbelievable how good it...
