OSH’26: The Annual Thread (RV Events, RV Announcements, RV PIREPs, RV Pictures)
And it is created.... Chime in with your PIREPs, events, pics, people, pooches and general news. Hope you have a wonderful time! This top post up here will be updated with the RV-heavy events that I a) know about and b) am informed of. v/r,dr Fire/Smoke Maps: - https://fire.airnow.gov -...
vansairforce.net
Nutplate question
Can anyone tell me what goes attached to the 2 nutplates circled in red ? (RV14A) Thanks for your help!
vansairforce.net
Rubber seals in vansRV-8, does any one pictures to share of there engine compartment so I get it correctly done
Rubber seals in Vans RV-8 does anyone have pictures to share of there engine compartment , so I can get it correctly done.
vansairforce.net
RV-14 aileron bone head screw up, pushrod attach nutplate- repair advice needed
Was rigging the completed -14 ailerons and needed to 'open' the corner nutplate (MS21053-L3) that attaches to the pushrod via the #3 screw. By 'open' I mean running a tap a little way into the nutplate so the bolt/screw can get all the way in tight. Been doing it a long time and works great...
vansairforce.net
Can a front mounted governor fit under a -4 cowling?
My engine developed a crack, I need new cases. I also want to convert to a CS prop. On the -4, adding a rear mounted governor requires notching firewall, using a front mounted governor doesn’t require notching the firewall , but the real benefit to me is that the case is stronger. Does anybody...
vansairforce.net
OFF TOPIC:
https://vansairforce.net/threads/the-vaf-list-a-list-of-rv-related-lists.223964/
vansairforce.net
Past ‘VAF News’ issues:
www.vansairforce.net
