Passed The Most Important Inspection
Just back from the paint shop. Passed the rigorous grandchildren ramp check……
www.vansairforce.net
Introducing … The Valkyrie Known as Myst!
The F1 flew for the first time this morning, and earned her name – the Valkyrie known as “Myst”. We did the first and second flights before noon - the first a quick short hop over the field to verify proper handling and engine/system operations (EAA Test Card 1) and the second (Test Card 2) to...
vansairforce.net
NEW RV10 PAINT JOB
The pictures really don’t do this one justice. Thank you Bobby and Alex for trusting us with your plane! Huge shout out to Autumn with Evoke on this design. If you attend Oshkosh this year keep an eye out for it!
vansairforce.net
Meditations on a Grounded RV
XXVI. On Baffles Upon an idle engine A divider to endow, In shiny sheets of silver Borders bracing on the brow, A royal crown for cooling On the queen of throbbing thrust, To guard against a galling Overheated head to bust; Behold! The angled anchors Latch the leaves upon the...
vansairforce.net
First Flight: Eileen Bjorkman’s RV-8 | Eugene, OR RV-8 #83465
https://www.vansaircraft.com/first-flights/eileen-bjorkmans-rv-8/
vansairforce.net
Engine pump to carb hard fuel line?
Just out of curiosity, why have I only seen hoses from the engine driven fuel pump to the carburetor? Pump and carb are solidly mounted to each other, so there should not be any motion/vibration issues. It seems to me that a nicely bent hard fuel line would be more compact and certainly much...
vansairforce.net
Clickbond nutplates: any advice?
I have to install a couple nutplates in a very difficult to reach location inside my fiberglass wingtip for my new navlights, a friend suggested I use these. Anyone have any experience with them? TIA
vansairforce.net
The extreme holes on each end are where I have to put a #6 nutplate, you can see where the previous nutplate and wire access hole was.
It's all part of the adventure.
Oil tube and engine mount interference
My engine (io 360) is mounted. When trying to screw in the oil filling tube won’t go into the engine due to the mount. I need about 5-10 degrees of an offset to get the tube in. I would imagine others had this issue too.
vansairforce.net
OFF TOPIC:
https://vansairforce.net/threads/the-vaf-list-a-list-of-rv-related-lists.223964/
vansairforce.net
Past ‘VAF News’ issues:
