dr
Rick57 Milestone
Got the first two solo flights done in my -4 yesterday. I've owned it since February and it was an exercise in patience and going here and there to get brushed up on the tailwheel skills again and doing transition in an -8. The ferry pilot stopped by and we did several circuits in his -6 in advance. He took off after me and flew my wing, landed before I did, and said landing looked like a sore-footed butterfly touching down. Ag Pilots do have a way with words. This is gonna be a fun challenge in flying this little plane well and safely. Now the learning and fun begin! Thanks to you all for your help. And Yeah, I'm working on the RV grin. It really comes naturally after a few minutes...be safe!
KEG
RE: Number 4 CHT
…ve0kog
this is what i see during runup - all EGsT raise during mag check. Interesting the #1 raises a lot more with the right mag off.
However on the takeoff roll #4 has the hottest EGT and CHT raise which is not detected during the 1800rpm runup (very similar to the OPs problem)
RNB
https://vansairforce.net/threads/fire-brake-during-taxi.235852/
OFF TOPIC:
WDYDWYRTW? 6 / 21-22 / 2025
*What did you do with your RV this weekend? Getting this weekend's thread started, and hope you're having a nice one. v/r,dr
www.vansairforce.net
Rick57 Milestone
Finally!
Got the first two solo flights done in my -4 yesterday. I've owned it since February and it was an exercise in patience and going here and there to get brushed up on the tailwheel skills again and doing transition in an -8. The ferry pilot stopped by and we did several circuits in his -6 in...
KEG
Stabilator Cable Tension
I am confused, AGAIN! KAI section 38iS page 17 refers to control cables are to be tensioned to 35-46 lbs. It also includes a note referencing the thermal effect on cable tension and says the recommended 35-45 lbs setting is for 70 deg.F. I have looked at several charts (Like the one below...
vansairforce.net
RE: Number 4 CHT
…ve0kog
Number 4 CHT
O-360, CS, RV6A, 1400 hours. Last two flights the CHT on number 4 cylinder started running 20 degrees hotter than ever before. EGT is a little hotter. I switched the probes from 2 to 4 and I don’t think it’s the probe. Replaced intake gasket and connection pipe. Compression check cold 75/80...
vansairforce.net
RNB
OFF TOPIC:
vansairforce.net
vansairforce.net
