The VAF News - 5.30.2025. #6352.
DeltaRomeo
doug reeves: unfluencer
Staff member
Wishing you and yours, a happy safe and RV filled weekend.
v/r,dr
DIY Paint Update ...Rob Reece RV-8
Blow up temporary paint booth in a friend’s hangar. Rob estimates it’ll cost him $8K to paint his RV (includes the booth). Fresh pics from Thursday.
v/r,dr
David Paule -3B Update
My carburetor has a female hose inlet that’s a -5. Or so I thought. The clues pointed in that direction. But have you ever tried to source -5 AN fittings? Fortunately, Tom Swearengen took one look at a photo and correctly identified it as an NPT. Sure enough, when I tried a 1/4” NPT plug, it fit perfectly.
With that taken care of, I placed an order for the engine hoses, firewall forward. The set consists of:
2x Remote oil filter hoses,
2X Oil cooler hoses,
1x Gascolator to the engine-driven fuel pump,
1x Fuel pump to the red cube,
1x Red cube to the carburetor,
1x Oil pressure sense line,
1x Fuel pressure sense line,
1x Manifold pressure sense line.
In the meantime and with considerable difficulty, I installed the cabin heat muffler. I used a Robbins Wing one and the best things I can say about it are that it uses two exhaust pipes and fits. The installation was hard because getting the side and end screws to line up was nearly impossible. Eventually, I had to open up the side screw holes to make it possible, and even then it took some fiddling.
The good news is that it does not need to be disassembled for condition inspections. There’s nothing to see inside.
XI. On Harnesses …Scott Chastain RV-8
RE: Lifting Tail Wheel W&B …clarenceoveur
My tail wheel weight is 57 pounds. I had the luxury of a proper jack stand designed to hold the tail wheel securely and then jack up to the proper height to level the airplane.
Ron B.
PaulvS RE: RV7 or RV9 canopy slider rear skirt fiberglass layup ….RV-6A
RE: Another Andair Fuel Selector Question …jonny’s RV-8
I have the newton valve and it’s a really nice bit of kit, but I’m not flying yet.
I think it’s the same valve that Vans fitted to the revamped factory -10.
Knowledge Review….always trying to improve.
LettersFromFlyoverCountry RV-12
As I work my way through PAP on the 12iS, some weirdness happening on PAP G4-2, enabling the starter circuit.
OFF TOPIC:
