Seen at SteinAir.com
A couple panels recently off the bench. An RV-14 panel that went to Australia, and a nice RV-10.
These folks do amazing work.
v/r,dr
OFF TOPIC:
https://vansairforce.net/threads/the-vaf-list-a-list-of-rv-related-lists.223964/
Past ‘VAF News’ issues:
v/r,dr
WDYDWYRTW? May 16-17, 2026
Here's 1030 CST Saturday. Lots of RVs a hoppin' Hope you're having a good weekend, and looking forward to reading the activities. v/r,dr
vansairforce.net
Need to replace a section of solid steel brake line in my RV-7 due to chafing...
Long story short, the right brake line that crosses under the engine was chafing on a clamp for the last 20 years - and it's now leaking. After looking things over, I think the best course of action is to cut out the damaged section (about 2 feet), plumb in a steel braid segment and adapt it to...
vansairforce.net
MicroEFIS 2.0
Did you look at MicroEFIS 1.0 and think "That's great Pete, but what else can it do?" ( No one said this....) Well have I got a deal for you! Introducing MicroEFIS 2.0! Same great glare-shield form factor, but now with rolling digits and an experimental carbon monoxide warning system...
vansairforce.net
Lycoming #4 CHT Too Cold
There's a title that might catch your attention. Over the past 20+ years, on two RV-7s equipped with an IO-360-A1B6 (200HP, Angle Valve, Roller Lifters, Piston Squirters, Dual EI, 20°BTDC base timing), one parts built (Aerosport Power - Bart Lalonde) and the lycoming factory, I've...
vansairforce.net
Alert: Tail Section 09-20, Part E-15008-001
UPDATED IN RED: I am finishing up my left elevator and have been jerked to a sudden stop by what appears to be an incorrectly punched row of holes. The outboard-most row of holes seem to be mis-aligned with the tail skin (and, likely, future fiberglass tip). I was able to Cleco the length of the...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
