Thanks again for helping keep this small 1-person business afloat with your 'badge'. v/r,dr
….seen at Richmond Aircraft Tue (Monk’s). Not an RV, but I thought it was a novel approach - this plane flies slow, BTW.
v/r,dr
Larry KMYA RV-14
DCBrown198
dr
dr
WheresMyPlane
RNB RV-10
N546RV
Fulltron Aviation (advertiser)
Knowledge Review
OFF TOPIC:
v/r,dr
Larry KMYA RV-14
Aileron push rod connection
Has anyone heard of or discussed a potential issue with the screw attachment of the aileron push rods. The plans don’t call for Loctite. I wonder if they ever work their way out. They could jam against the flaps and cause some real trouble! In view of the recent accident of Rob Hollander I...
vansairforce.net
DCBrown198
Stripped screw hole on longeron at rear inspection plate.
The paint shop got a bit aggressive reinstalling an F824-B inspection plate at the rear of the empennage (below elevator). There are a couple of 507C-6 screws that screw into the longeron itself. The tapped longeron hole got stripped. I'd like to rivet a nutplate to the longeron to accept the...
vansairforce.net
dr
WDYDWYRTW? 5 / 10-11 / 2025
The spousal unit was teaching a free yoga for cancer patients class via Zoom from our living room Saturday morning, and that includes about 15 minutes of meditation, so my role is to be gone during it. Airport! 30min droning around the local area in the 'ol RV-6. Saw a couple new water tanks...
vansairforce.net
dr
First Flight: Fabio Ziglio (Italy)
https://www.vansaircraft.com/first-flights/fabio-ziglios-rv-7/
vansairforce.net
WheresMyPlane
SkyView glitching
My skyview has started glitching. Screen goes to multi-color vertical lines and quits working, sometimes while in flight. Switching it off and back on seems ro fix it temporarily but it is starting to occur more frequently. Any idea what the cause of this glitch could be?
www.vansairforce.net
RNB RV-10
Problem with bottom rudder hinge bracket (VS)
My VS is together but I am having a tough time putting the bottom hinge bracket on. The four screws AN509-8R11 don't fit very well in the supplied nuts MS21042-08. The nuts appear a bit lopsided, misshapen. I assume this is because they are designed this way for locking force. I do not have...
N546RV
Houston area monthly lunch (May 2025)
It's that time again. B-52 burger time, that is. Or maybe "ew I have to talk to ATC if I want to fly in" time. Anyway... When: Saturday, 5-17, 11:30 AM Where: Aviator's Grill at Hooks (KDWH)
vansairforce.net
RV9A NEW PAINT JOB!
Thank you, David Harms, for trusting us with your beautiful RV9A! We love how it turned out. Don't miss the ghosted VA on the vertical stab!
Knowledge Review
OFF TOPIC:
vansairforce.net
vansairforce.net
