The VAF News - 4.15.2026. #6525. Turbo’s new panel, SnF Arrivals, 1stFlt, Static, F1 progress, 3D hammer holder, Fastener.
DeltaRomeo
doug reeves: unfluencer
Staff member
Turbo’s new panel
Lifelong buddy Scott got a new panel in his RV-7 (been flying for over 15 years). Very simple, but packed with an insane amount of flexibility. Plenty of room for the iPad also.
v/r,dr
SnF Arrivals
Thought you’d enjoy a ForeFlight screen grab of the SnF activity around 6pm local time. The app depicts the arrival route.
v/r,dr
Had some fun working on the static system needs this weekend.
I had bought the SafeAir1 system AGES ago, so figured I’d stick with it…ish.
After reading all the threads on the static errors seen with ports that weren’t the “Vans standard” SD-42-BSLF rivet, I went a “hybrid” route.
Simply put, I filed down the nubbin machined in the face of the SafeAir1 port and drilled the now flat face to #30. Then simply drilled the standard #30 hole in the skin at the DWG 28 location (NOT the often missed and confused Static Port Kit Instructions location for the RV-6).
The last mod was to remove a little from the side of the port fitting face to clear the bulkhead flange before ProSealing the flange to the inside of the skin, and the rivet (less the mandrel) to the outside of the skin.
OFF TOPIC:
https://vansairforce.net/threads/the-vaf-list-a-list-of-rv-related-lists.223964/
Past ‘VAF News’ issues:
