ON for Good.
My buddy Rob Reece attached the front windscreen on his -8, all sealed up and on for good. Love that all the screws line up perpendicular to the edge of the fairing edge (his Dad used to be in charge of experimental judging at OSH).
Happy for my friend, and looking forward to his first flight.
v/r,dr
That's why the horizontal induction sump typically has a sniffle drain. The yuck pools in the plenum. Yours pools in the airbox.
Induction leak --
Set the chart to 4, thence Chart 1 - EGT, Chart 2 - FF & Fuel Pressure, Chart 3 - RPM & MAP. Excerpt from Chart 3 attached...
The MAP should decrease when you close the throttle -- instead it increases to ambient pressure...
FLIGHT ADVISORY GPS INTERFERENCE TESTING
FORT POLK LOUISIANA (FTPKLA) 26-07 (REVISION 1)
05 – 24 March. Fort Polk, LA
I put mine on after doing the upper hinges. Drilled the rivets out, removed the hinges, layer out the Skybolt brackets (required trimming the flanges), added the spacer strip back and match drilled the brackets. I used 16 with the last one under the engine mount attachment, and just above the vertical lower cowl hinge.
OFF TOPIC:
Past ‘VAF News’ issues:
v/r,dr
Oil in my filtered airbox
I probably should have asked this question long ago, but can someone tell me why I'm getting a fair amount of oil in my filtered airbox, making a bit of a mess of things? This is on an IO-320. Every time I change the oil (which is every 25 hrs), the filtered airbox is a mess, requiring...
vansairforce.net
Sudden EGT spike on all 4 cylinders
While doing light aerobatics (3-4G) at around 2400 RPM, full rich mixture, 5k altitude, I suddenly got a high EGT warning with all 4 cylinders above 1500 and some around 1580. No controls were moved just before or during the incident (at approx 18 min on the first graph). Never seen EGT's that...
vansairforce.net
First Flight: Greg Tilford’s RV-14A | Cincinnati, OH RV-14A #140192
I wanted a project that I could enjoy with my sons. Building an RV was a great way to spend quality time learning some things together….not the least of which was patience 😉. The plane flew beautifully, and phase one is progressing nicely. I’m incredibly grateful to my wife and sons for their...
vansairforce.net
FLIGHT ADVISORY GPS INTERFERENCE TESTING. 05 – 24 March. Fort Polk, LA
FMI: https://www.faasafety.gov/files/notices/2026/Mar/FTPKLA_26-07_GPS_Flight_Advisory_(Revision_1).pdf
vansairforce.net
Skybolt Fasteners - Order of Operations - RV14
I would like to replace the upper cowl piano hinges with the skybolt kit (already bought it). I do not have my upper fuselage skin riveted on yet, as I have not finished my avionics. I did do the dual access panel mod already though. My upper skin is just clecoed and its a tight fit/stretch to...
vansairforce.net
Keeping oil door open
I remember seeing a post in the past, but can't find it with search. How are others securing their oil door open? I have a spring loaded oil door, but looking for suggestions on how to secure it in the open position beyond the spring force when I walk away from the plane on the flight line for...
vansairforce.net
Really dumb running wiring question I need to ask
I think it was Churchill who said It is better to keep your mouth shut and look like a fool than open it and prove it, but Churchill was a Lord of the Admiralty, not a kitplane builder. I need to run some 20 ga power and ground wires to the master solenoid and starter contactor for a Rotax...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
