jacknife Travel Tool Kit
Mark Palauan
…7A project for sale.
nohoflyer
Benchmarking oil temperature on RV-14A with Lycoming 390 EXP
…Reflex reply
SomeGuyInCentralJersy
Excitement on Climb Out (rough running engine)
…Alex Hardy reply
Metzger130
kirkbauer’s Duel Bus Diagram
OFF TOPIC:
Anyone care to chime in on what’s in your travel tool kit?
I had one for my -7 but let it go when I sold it. Looking to build another for my -4. I’ve got the basics like screwdrivers, sockets, wrenches, Allen wrenches, tire gauge, pliers, spare spark plug, safety wire, spare inner tube, zip ties, 1 qt of oil. Anything else I’m missing? Thanks! Ricky
vansairforce.net
Mark Palauan
RV7-A Project for sale
RV 7-A project air frame $30,000. Selling because of vision loss. Kits purchased between 2006 and 2010. Quick-Build Fuselage and Wings. Wings stored in cradle with flaps and ailerons attached. Fuselage on gear with Aerosplat and empennage attached. Tip-up canopy and cowling complete ready to...
www.vansairforce.net
nohoflyer
ELT mount technique
I installed my ELT (I can move it if necessary) 90 degrees from the instruction recommendation. Can anyone tell me why I wouldn’t want this spot? Seems to fit perfectly and is out of the way of any cables.
vansairforce.net
…Reflex reply
Hi all, I'm on my second flight, getting used to my airplane temperatures, and trying to understand what will be its "normal" temperatures. Would like to ask other RV-14/EXP390 owners to share what are the average CHT and oil temperatures you are observing with cowl flaps open and closed. Mine...
vansairforce.net
MS20074-05-06 torque question
Hello group, hoping experts can weigh in and clarify how to determine correct torque for alternator bracket to engine (RV14 390). These bolts are 5/16-18 course thread. AC 43.13 charts show specs for bolt and nut combo, but what about when the bolt goes into the engine?
vansairforce.net
…Alex Hardy reply
Yesterday we had a bit of a break in the weather, so I decided to exercise the -7. All was normal with the run-up except the #2 cylinder was lagging behind the others in EGT/CHT. I've noticed this for a while but everything was running well so no action taken. The takeoff roll was normal as...
vansairforce.net
Metzger130
G5 G meter?
I have just updated my panel. Gotten rid of a Dynon D10A, updated to a dual G5 setup. Just realizing I have no G meter anymore (D10 offered it) Does the G5 offer G meter anywhere. I can’t find that it does🙃 Old panel and new for clarification. I do a lot of formation and gentlemen aero. Would...
vansairforce.net
Are 'Always On' Avionics a bad idea (Smoke in the Cockpit)
I am planning my RV14 Electrical system for an electrically dependent engine - it will be IFR, so some items of avionics will be essential for all phases of flight. The question is: Is it a bad idea to have some avionics (such as the PFD) always powered on, even when the master is turned off...
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
