The VAF News - 3.30.2026. #6518. (12) Fresh RV News Items. And good morning.
DeltaRomeo
doug reeves: unfluencer
Staff member
What MOSAIC Means for RV Owners
The FAA’s biggest regulatory shift in 20 years is here. Here’s what actually changes and what doesn’t.
So the epoxy with micro works well. Even though I used the 206 slow epoxy (next step: buy the 209 extra slow hardener) it only gave us about 10 minutes before it started to harden, with spring here and the temps warming up. But a dab of epoxy with a toothpick held vertically works well, and it sands down nicely with 220 then 400 grit. Also needed is a scale that goes to .01 grams to measure the epoxy in small batches.
The shop is really filling up. Once the aileron weights and counterbalance tubes show up I can get the ailerons finished. And I expect to have the rivets filled on the flaps and ailerons next weekend. Hopefully those parts can then go out to the hangar.
It's possible the Arduino or the Pololu DRV8801 driver board on the AV-60000 Power Module are going bonkers. They are both powered by the Trim/Start fuse, and are rebooted when you pull and reinstall the fuse. It could also be the small voltage regulator that powers the Arduino.
Look at the AV-60000 schematic and you will see all of them.
OFF TOPIC:
Past ‘VAF News’ issues:
