The VAF News - 3.21.2025. #6302.
DeltaRomeo
doug reeves: unfluencer
Staff member
Wishing you and yours a happy, safe and RV-filled weekend! v/r,dr
nplayle
azrv6
RE: Abnormal Stability in RV-6?
…skyboltr
Today I removed the washers from the upper lord mounts and here are a few before and after pictures. The washers were adding just under 1/4" (.240) of nose down cant to the thrust line. Now the spinner is more correctly aligned with the cowling. I couldn't test fly today as the winds were rather gusty 90 degrees to the runway. I am quite confident that this was the issue all along but will post the resulting change in the flight characteristics as soon as possible.
RV-3B Dave's in Colorado
…FAB update
The FAB manual gives a procedure for extending the inlet snout on the cowl. It involves shaping some provided foam and glassing it, followed by some other steps, including more glassing. The shaping went okay but when I tried to glass it, the glass would not adhere to the inside of the foam on top. It made a sticky mess, sticking to my gloves, sticks or anything else I tried to get in there, sticking to everything except for the upper inside of the foam. I removed that glass.
Reset.
I bought some balloons and with them in hand, used reinforced packing tape to wrap around the exterior of the foam, so that the balloon would not burst it.
AJPope
joer308 RV-14
RE: Wing Tip Attach - Pop Rivets, Screw Nut Plates or Piano Hinge.... Thoughts
…Carl F.
I fill in the fiberglass tip trailing edge rib (along with all control surfaces) so piano hinge do not work. #6 SS screws but I add #6 tinnerman on the screws to protect the wing paint.
Made my own wingtip VOR/LOC/GS antenna - it is attached to a piece of 0.032” angle on the outboard wing rib. That way the antenna stays on when the tip come off.
OFF TOPIC:
