Mateo's first flight!
After begging me for a year, I finally took my 3.9 year old Grandson up for a ride!
vansairforce.net
Threads/helicoil backing out
Threads backing out of #4 top plug. Any insight to a solution/fix would be appreciated. O320 ~1900 hrs SMOH
vansairforce.net
EZ-DRAIN - Emptying (horizontal) Oil Filter
Here's a little "gadget" I make to empty horizontal oil filters @ oil change - YMMV - and probably does! HFS
vansairforce.net
RV-15 #150046
Picked up kit on Feb 9. Unpacked and inventoried. Now taking up space in the family room.
vansairforce.net
Borescoping cylinders: "Gunk" on piston
Engine's got about 160 hours on it. Whenever I stick a borescope in to have a look at the inside of the cylinder, the cylinder walls and the valves seem fine and clean, but the tops of the pistons all have what I can only describe as "white gunk" on them. I've seen other borescope pictures of...
vansairforce.net
Rudder stop product
Hello, I am update the lower hing/rudder stop with SB and I had found this product, seems a bit more forgiving since its not metal hitting metal. https://flyboyaccessories.com/products/internal-rudder-stop any thoughts on it, worth it?
vansairforce.net
OFF TOPIC:
vansairforce.net
Past ‘VAF News’ issues:
www.vansairforce.net
vansairforce.net
