The VAF News - 2.7.2025. #6272. TGIF!
DeltaRomeo
doug reeves: unfluencer
Staff member
The OVC was forecast to get to a height where I could do some TnGs by 10am Thu, but it didn’t burn off fast enough for my window of opportunity,. Many sims this weekend, so maybe in a few days we’ll try again. Nature of the hobby this time of year here. Wiped the RV down a little, checked the oil, and straightened up some stuff as the alternate - still good!
Wishing you and yours a happy, safe and RV-filled weekend.
v/r,dr
Wagner
Per the plans; pre-bending the hose clamp then carefully cinching it down around that 5" SCAT tube about the oil cooler plenum flange, worked out just fine - it has remained secure as of 75hrs hobbs. Oil temps on my IO-390 EXP-119 Thunderbolt are running just under 200degF
HFS
dwollen89 7A
RV White Pages Updated
….in the VAF List.
Electric Puzzler Update …bjdecker
baffle/Oil Cooler Crack Update …echostar7
The repair we decided to go with was replacing the cracked baffle for #4 with a new one from vans and adding an additional .032 angle to stiffen the #4 baffle, crossing my fingers that the repair lasts. It was not possible to use all solid rivets for the repair due to access issues.
https://vansairforce.net/threads/baffle-oil-cooler-crack.231409/post-1822912
OFF TOPIC:
