searv6
RE: Brake Rebuild Kit …azrv6
JRStocks
YME
dr
RE Sniffle Valves. Majorpayne
Repainted! rvator51
MattChaloner
OFF TOPIC:
…courtesy Randall Henderson
O-360 too lean before carb swap, to rich after.
Hey brain trust. I have a 6a with an field overhauled Mooney C o-360 with 200hrs, CS MT, one slick timed at 23* and one Surefly with advance activated at 20* When the motor was first built it had a ma-4-5-10-3878M. It was freshly overhauled. It always ran hotter then hell itself on takeoff...
vansairforce.net
Cleveland Brake Master Cylinders
I have an RV6 with Cleveland Brake Master Cylinders (10-30). The Van's catalog currently has replacement master cylinders in their catalog that appear to be made by Matco, offered for the RV-6. Does anyone know if the Matco Master Cylinders offered by Van's are a direct replacement for the...
vansairforce.net
JRStocks
Rv-4 Cowling Work
Saw a couple of you guys posting that you’re working on cowlings-you’re not alone. Pretty tedious process so far. Curious what you guys have for your hinge pin where the halves meet. I’ve seen Aerosports covers-any other options out there? I see a couple other builders posting that are also...
vansairforce.net
YME
Stabilator fairings help....
Started Stabilator Fairings and got a question above the recessed area. As shown in the plans they want a sharp inside corner so the the skin is somewhat flush with the fairing. See pic I have a hard time getting that done. Tried using a file with edge teeth but not happy with results. Has...
vansairforce.net
dr
WDYDWYRTW? 2 / 1-2 / 2025.
...getting this weekend's thread started. Hope you're having a nice one. v/r,dr
www.vansairforce.net
RV-8A Sniffle Valve Tube Pictures?
Mine just dumps straight onto the cowling making a mess. I’ve been meaning to make a tube of some sort so it dumps past the cowl. Any pictures from 8A builders for ideas? The 8 is easy because you don’t have the nose gear in the way.
vansairforce.net
Repainted! rvator51
MattChaloner
Vertical Stabiliser middle nose rib riveting
Hi All, I’m now progressing my empennage kit and have had inspector sign off to rivet the skin in place on my vertical stab. I missed up 1 of the rivets so I drilled it out and put another in before moving on. Having now riveted the bottom nose rib in place I’ve noticed that the “redone” rivet...
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
