Got to have breakfast Saturday with an RV-4 owner who was in town. Always a treat!
Hope you had a great weekend,
dr
OFF TOPIC:
Past ‘VAF News’ issues:
dr
WDYDWYRTW? Feb 21-22,2026
What did you do with your RV this weekend? Getting this weekend‘s thread started. Here’s what’s in the air 9:45 AM Saturday morning. I hope you have a wonderful weekend! v/r,dr
vansairforce.net
CHT 3 no reading
So my number three CHT is not reading. Things are opened up so I changed the number three probe and powered things up, still nothing. I left the system on and wiggled the firewall forward wires, searched for a short. Nothing. I guess I need to open the panel up and see if things are loose in...
vansairforce.net
Successful Second Flight
As some of you may have read the previous post about my eventful first flight thread, I've since done my second flight, this time I can happily say it was a success. I flew for 30 minutes at WOT at ~2500RPM orbiting my airport. the plane flew beautifully! I can seriously say I got bored doing...
vansairforce.net
Electric Preheat Inlet Hardware
For folks who have onboard electric engine preheaters, what elegant ways have you found to receive the incoming AC power? So far I have tried a flopping around male plug and a hard mounted right angle plug, both accessible from the engine cooling outlet at the bottom of the cowl, and neither...
vansairforce.net
Aileron bellcrank and pushrod assembly
In the KAI pages 28-19, 28-20 and 28-21 dealing with insertion and assembly of the aileron pushrods there is a difference which I am unsure about: On page 28-20, the callout is only for one washer for each rod end assembly. For each of the other two assemblies, there is a washer under the...
vansairforce.net
Is the SL-00070 strainer inspection port worth the effort?
Hi guys, I've already finished building the IS fuel tank and leak-tested it, and only noticed the inspection port kit afterwards. Installing it will require removing the plate, drilling the hole, resealing it, and performing a leak test again. I'm not sure how hard it is to inspect the...
vansairforce.net
Dehydrator & Oil Separator
I have my engine on a closed dehydrator loop while it sits on the plane in my garage as I finish the build. I'd love to have the option to keep the closed loop for humid Seattle winters when I may not be able to fly as frequently as I'd like (I've tried an open loop in the garage - it goes...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
