The VAF News - 12.24-26.2024. #6241. Merry Christmas everyone!!!
DeltaRomeo
doug reeves: unfluencer
Staff member
dr
RE: ShawnR’s RV-4 Build
An issue came up that I have not seen a lot posted about. It is mentioned at the end of this thread in post #11 but not resolved. I am having the same issue. Any else have to deal with this? I feel like the tube is too close to the mount, and engine vibrations could cause issues. The tube is all plastic.
RE: 9A Cabin Heat
…rockwoodrv9 PIREP
I have an exhaust that may be different than many on an 0-320. It produces almost no heat - even for the carb heat. I have not found a way to get more heat. I have sealed every place I can find - put the aileron boots on and weather stripped the rail and canopy. There is still leakage around the instrument panel that I think comes from the tip up canopy seal along the foreskin. I tape over the exterior of the vents so no air can come through.
Here is a picture of my exhaust system. If anyone has an idea on how to increase the heat, please let me know. I was going to fly yesterday but it was in single numbers and that is too cold even with heated vest and heated seats. I talked to Clint last year about building a new system and that may be the best answer.
3D Printed Phone Cradle/Kneeboard Idea (dr)
….update
Aircraft Extras, Inc. RV NEWS
Take a look at our “E-Z Out” Center Console for the RV-6, 7, 9, and 14. The center console not only adds more storage space, but you also may use it for leverage to get in and out of the aircraft. They are solidly constructed so that you can put your full weight on it as long as you secure it properly upon installation. We presently have stock on all consoles.
We also make other interior pieces such as seats and side panel armrests.
Don't forget to check out our NEW "Oil Quantity Sensor" and some of our standard products; No Weld Handles, Relay Boards, Flap Positioners, Low Fuel Warning, Smallest Annunciator and our Tire Valve Extensions. Also check out these items below for some stocking stuffing
More details at www.aircraftextras.com.
OFF TOPIC:
Off-topic is very nearly on-topic. Can read as procedural warning: if name != {'St. Nick' OR 'Father Christmas' OR 'Santa Claus'} then: invoke abort_landing.exe that would prevent some unfortunate near-miss events by wayward pilots mistaking the pictured decoy yard for a safe haven! I sure hope this Flying Griswold animated the "rabbit" sequenced approach lights too! Don't want Santa to have to go missed due to inop Cat III lighting in low IFR!
dr
RE: 9A Cabin Heat
…rockwoodrv9 PIREP
….update
OFF TOPIC:
MERRY CHRISTMAS to all
